Plugin Updates (Official Store)
Audio File and MIDI File updated to 160.0-13
The resampler in use for Audio File (zita-resampler) was updated to its latest version, which brings ARM-specific optimizations. This makes loading non-48kHz files faster.
The MIDI File player is updated along side it as they belong to the same plugin bundle, but no changes were made to it.
MOD Cabinet Loader updated to 2.0-15 and MOD Convolution Loader updated to 2.0-22
Fixes the current/active IR filename on the modgui for pedalboards imported from the pedalboard feed at https://pedalboards.mod.audio/
Audio File and MIDI File updated to 160.0-14
Fixes playback of certain audio files that fit perfectly into an internal buffer, leading to reading the whole file and playback skipping weirdly right after start. Happened with at least 32bit mono wav files.
Same as before, MIDI File player updated too but only because they come from the same package.
AIDA-X updated to 1.0-14
Last update changed the behaviour of the bypass, which was not intentional. Now corrected.
Spoke too soon in regards to clickless bypass, that is not a thing here after all…
But in return bypassing the plugin will cut off on CPU usage.
The Rude updated to 1.0-9
Tweaks to its output gain compensation curve (based on the “ratio” knob) and some minor branding details.
MOD Bass, Modern and Vintage Cabinets updated to 2.0-12
We have changed the convolution engine used by these plugins to one that is much more efficient, reducing CPU load considerably. Because of this the “high-fidelity” parameter is gone, as it is no longer necessary.
Please open a new topic on the forums if this update causes any issue for you.
setBfree Whirl Speaker updated to 2058.0-3
We moved the plugin from Simulator to Modulator category, no other changes.
AIDA-X updated to 1.0-15
We now expose the DC Blocker filter that runs at the end of the processing chain on AIDA-X as a switch, in case anyone needs to turn it off (not recommended unless you know what you are doing).
Also the Antialiasing parameter turns that filter fully off when at 0%.
Both changes are optional and will not change the sound on existing boards, but are useful for some of our internal testing.
forward audio ENG 212, faIR Modern Rock, Marsh 1960, MEGA California Recto updated to 2.0-10
Same as the MOD cabinets a few days ago, we have changed the convolution engine used by these plugins to one that is much more efficient, reducing CPU load considerably. Because of this the “high-fidelity” parameter is gone, as it is no longer necessary.
MOD EZComp updated to 1.0-7
The internal model file was updated to a more robust one, taking away the “distortion”-like effect that was sometimes present on the previous version
AIDA-X updated to 1.1-16
Improvements to model loading for having less clicks while doing so
Codebase was cleaned up a bit to more easily handle the commercial plugins based on it.
Also updated all other AIDA-X based commercial plugins to match the latest improvements.
CollisionDrive updated to 1.3-3
GxBaJaTubeDriver updated to 35.0-6
GxKnightFuzz updated to 34.0-9
GxSlowGear updated to 34.0-9
GxSwitchlessWah updated to 1.2-12
This makes them in sync with fixes made to be able to support Windows and macOS, so they can be integrated on MOD Desktop.
Only GxSwitchlessWah has functional changes, with new min/max controls and new modgui
