Plugin Updates (Official Store)
MDA updated to 0.4-14
This brings a big set of changes to these plugins related to converting more 0-1 normalized parameter values into real values.
Additionally, Degrade and Shepard were moved from beta to stable.
This is a backwards incompatible change.
Please update your pedalboards that make use of MDA plugins after installing the plugin update, as some parameter ranges and units were changed. This can be done in steps:
  1. fix addressings (first unaddress, then readdress, especially needed if you notice parameter values outside of their available range)
  2. fix snapshots (load snapshot, fix state, save snapshot)
  3. fix pedalboard (after fixing all addressings + snapshots, save the pedalboard)
Consider backing up the unit data (through advanced settings with a usb stick) before installing the plugin updates in case you use them a lot and require them to work just as they were before.
