I have chocolate plus since some months ago and never happen to meā¦
Do you have last firmware in chocolate?
I think Iāve figured it out, at least in part. When assigning cc values i did not always select the code int the āVisual behaviorā list that popped up - I only changed the value on the interface page. When I went back to the dwarf interface to test and save I was only watching to see if it actually did what I intended, and only glanced at the message that popped up in the upper right hand corner, mainly to verify that the dwarf was recognizing input from the controller. At some point I looked at the pop-up message more closely and noticed that the code it displayed was not the one I had entered on the interface page in the CubeSuite app. I obviously had not read SrMouraSilvaās intro closely enough and had not noticed the faint white line under the cc code on the āVisual Behaviorā list. That solved that problem.
Part of my problem is also my limited understanding of midi. In my frustration over the above problem I began to change things that I shouldnāt have and lost the changes I had made that did work.
In short, this was a classic case of āuser errorā.
In regard to firmware updates - I havenāt been able to find any info about that on the M-Vave site.
Thanks for your help! Looks like my assignment for today is to read SrMouraSilvaās intro more closely and learn a lot more about midi. Iāve even started looking into json.
Okay, update time. Twice since my previous post Iāve fired up my rig and the Chocolate had lost itās settings. At one point I thought Iād figured out why and how to avoid that, but the last two times I had to open the app on my phone and connect to the controller over BT. The settings came back. That didnāt give me a lot of confidence that I could count on getting to a gig and firing things up and having everything work. It never does anyway. This just added another element of uncertainty. That - plus the lack of LEDs - prompted me to return it.
Itās an excellent learning device though, and it does what a midi controller should do. I just didnāt want to deal with another possible point of failure. Iām enough of a point of failure all by myself!
This is a great thread for the midi info alone. Iām sure Iāll be referring back to it in the future, but for now midiās on the back burner.
Many thanks to SrMouraSilva and to everyone who contributed!
If it were possible to edit the labels to personalize what appears on the display would be perfect. But the Gossiper is a hand on the wheel! if I could edit the text as the āMulti Button CV MODā does would solve the issue.
The changing label is in my queue. But I didnāt have time to check it. I am also with problem to connect Dwarf into my computer. I need to fix this firstly
This is good to know. Thanks for this tip!
hi, iām considering buying the M-Vave pedal to use a page turner with the OnSong App, has anybody tried this?
I currently use an Airturn 500-S4 but since ios 26 it no longer works reliably and as I gig several times a week I need something that will just work.
Does this pedal use internal bluetooth or will i need to buy a dongle?
OnSong does use midi but the ipad is mounted in a dock so rules out the usb-c connector.
Any advice would be welcome before i go ahead and buy one.
Yes there is a buit in bluetooth.
I use it as a page turner for Forescore on my Ipad.
