Does it just happen with the host sync? Do you have the tempo tool with play active? Sorry if it’s a stupid question. This quite seems like getting life on it’s own
Hi @jon! By “tempo tool in with play active” I assume you mean the global tempo/play function, and the answer is yes. The click to keep time is a midi-sequenced snare with host sync on (obv not running through the looper).
Yep, that was exactly what I meant. I assumed that the answer was “yes” indeed. Let me check with my colleagues if this is a known issue.
