I am reviving this topic.
i would like to set looperlative in a “rec” mode where i am thinking to use “host sync” rather than “self sync”
Basically i want the loop to sync with the internal dwarf tempo to make sure the recorded audio on the dwarf reflects the tempo set and can be imported later in any DAW/sequencer.
Would this work as i expect?
Yes, recording with host sync will sync with the internal Dwarf clock.
thanks for confirming, I will have a play with it
