If I use A B C 3 pedal , can I use CV setting 4 function?
- A B C Off
- A on / B off / C off
- A off / B on / C off
- A on / B off / C on
how can I to do this?
Yes with this beta plugin Tetr4Switch
Wow Cool ! Thank you
How can I use Gitrhub source code yo my MOD DWARF ?
Sorry I not good for this…>_<
Tetr4Switch is indeed a good option.
I suggest you also take a look at the tutorial about Setting up Macro-Controls using CV. That may also help you ![]()
It’s in the beta store, you can allow beta plugins in your Dwarf’s parameters and louk for it in the store
I second the recommendation to look into CV, because you can have one CV control scaled in different ways for different destinations - beyond just the on/off type thing.
Thank you so much ^^
