awesome! having the mutible plugs would make this complete ![]()
Another suggestion… a slew/portamento module please
Plugin has been updated on beta store, now using 22.07 matching the upcoming release in a few days.
The important change is full screen requests now fully working.
There is still the issue of using text editor module causing potential patch breakage, will investigate that more at a later time.
@Blindsmyth this 22.07 version now has Bogaudio AD in the mini variant, as you requested.
Thanks for this upgrade! I apreciate adding the ad envelope ![]()
Try connecting the plugin output to your speakers. The visuals in the plugin window may not fully update.
right, the mini GUI will not react to MIDI signals, though it reacts to audio and CV.
so it could appear as if it is doing nothing.
Ah yes that was it! I saw the gui react to the oscilator but not the gate from the midi input. Thanks!
Hows this coming along?
it is not. tricky situation and other priorities come into play.
Oh…
Hi! Just updated to 23.10.9 to discover plugin is not working. No modules are visible.
I am with Dwarf 13.3 and Ubuntu 22.04.
CardinalFX and Cardinal seems to work as before
Works fine here on my DUO X LE
Ok. I`ll have a check again today.
Did a check. seems to work fine on my DuoX, but Dwarf shows the strange behaviour as before. No plugins visible in the Gui. Tried to remove and re-install, but same behaviour. Here`s a screenshot. What should I do?
I am on Ubuntu 22.04 and Latest firmware on the Dwarf. Also latest upgrade on CardinalMIni.
Hi all. The plugin was displayed normally from the beginning, but now it always has a graphical error (I don’t know how to fix it)
I have the same problem in both browsers. Win10
Mozzila and Chrome
5 posts were split to a new topic: Converting MIDI CC value to pitchbend
Any luck?
Hi! Thanks again for this great plugin! I was thinking that the Nimbus plugin from SurgeXT could be a great contribution to Cardinal Mini, since it`s original Clouds from Mutable Instruments has become somewhat popular with ambient and experimental guitarists.
why not, we are already using surge there so enabling more plugins from them doesnt take too much space.
So now in 24.05 there is Nimbus in Cardinal Mini, updated in the beta store as usual.
