Done !
With portal plugin (48% of the Dwarf’s CPU) :
And without (57% of the Dwarf’s CPU) :
After going back to you original pedalboard, the solution without portal is exactly the same CPU consuming as yours. But you have a better way to control your sends to the reverb/delay.
Yep… I can try but I think falkTX did a pretty good job here : Introducing Portal
